JsyCuPrA
225
18
Oxfordshire
Visit site
Car had a visit to Dialynx Performance, as my stock clutch was slipping on Revo stage one, so car now has a SACH Performance clutch and also Revo Stage one was upgrade to the higher torque map.
Pew.
1,451
142
Scotland
:thumbup:
Pew.
1,451
142
Scotland
After a moment of idiocy and discussion with the old boy on here I learnt to read instructions properly! Couldn't get the OEM intaki installed back on above the radiator, simple mistake of connecting a bracket 5mm to the right of where it should have been. Now fully rebuilt
Jay280
252
62
Went down to the awesome gti summer bash and took advantage of the sale offers
Reactions: Damo H
Maypack
Apr 20, 2014
3,175
2,330
Gods Country - West Cumbria
Averaged 42.2mpg on my 20 mile commute to work in my Cupra 300. Checked the Ecotrainer and I had scored 97 out of 100.
No way I’ll have that mpg on the way home in the morning. More like 25-29mpg then and I daren’t even look at the Ecotrainer!!
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Updated maps to v1030, altered throttle response to linear or whatever the opposite of factory setting is (I got fed up with jerky starts in dsg) and stopped cupra button lighting up when in cupra mode.
Deleted member 103408
Update Audi coding is
Select Control unit 01- Engine
Select Long Coding (1)
Select Byte 0,
Change Bit 0-2 from Seat to AUDI (02)
this will reduce lag on pressing accelerator pedal.
Not tried it so don't know, that is why I was asking.
Some commentators say on the lower level models it makes a big difference others say it impacts all.
if you go here
and from the index select the last item (12/ Performance changes non engine) this will show you all the coding for items that apparently make the car handle / respond better.
The change that kiddo made is in there as well.
JsyCuPrA
225
18
Oxfordshire
Visit site
Select Byte 0,
Change mine last week, but soon changed it back as it stopped the cruise control working.
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
I haven't had chance to give the direct acceleration - throttle response change a decent test yet. I haven't tried the Audi engine response but will give it a try if anyone reports a positive experience of the change.
Thanks I will also try it in the morning and see if I get cruise control issues, @JsyCuPrA is your car facelift or pre facelift
