loutje
www.vape-inator.nl
Is there an update for mib1?
hw:039
sw:171
update from 0132 failed lasttime, is the update working from 171?
is there also a crack for map updates?
thanks in advance.
jacko5
187
35
61
UK
Before i do the update ( 5F_0480 Mib1 ) is this ok for my 2014 mib1 unit
Hardware 040
Software 425
Cheers.
Harrymorgan1
Seat2016
Mar 5, 2017
24
Hey all, I have a seat leon 2016 with the below specs and am wondering if it’s possible to update my media system? I’m confused as I have read some posts say hardware h24 can and some say they can’t ? If I can can someone tell me the steps I have to do, the download link for the latest version and if I need to upgrade by version each time or can I jump straight to the latest ?
Hardware -H24
Software - 0241
Device - 5qa...
thanks!
matt_s
4 8 15 16 23 42
Dec 23, 2004
656
19
Will not clearing fault codes after doing the update cause any issues? I've got the latest software for the mib1 system to install but I haven't got anything like vcds or obd11 yet.
jacko5
187
35
61
UK
Hi,
Where did you get the latest software for your mib1 system ?
Thanks.
Amr Ezat
Device number: 5QA035824
Hardware: H24
Software: 0245
Media code : 2101.0.0.10
Is this device support any new updates?
And if yes how can i do that?
ibxxx
8
Hi,
Can someone tell me if there are updates for mine?
Device number - 5qa035858
Hardware - H24
Software - 0241
If there is, can someone provide a link please? Thanks
ibxxx
8
Hi . Thanks managed to update software . Any help with maps , I have tried on seat site but wouldn't recognize software when I put sd card in . I followed the guide twice . I have 6P0
SteveGSXR600K1
596
198
There is another massive thread that shows you how to update the maps. Don't bother downloading the update from the SEAT site as it is still at the 915 version. Go to VW website or download 1030 from here:
http://vw-mapscdn.tdd.adacorcdn.com/DiscoverMedia2_EU1_2718_1030.7z
Hopefully, you backed up the files from the SD card before your previous attempts as you need to put a file back on the SD card called OVERALL.NDS. If you didn't, you're stuffed..
SteveGSXR600K1
596
198
To clear the SVM error 1555 with XOR, MirrorLink option disappearing, SETUP aircon, etc, do you need the standard OBDEleven or do you need the PRO version? These are all the possible issues that are at the end of the installation instructions from the Spanish website.
ibxxx
8
Hi yes all backed up and put back on as card . I will try the link . Thanks
ibxxx
8
Hi, is it the same procedure to update, just extract to sd card and job done ?
ibxxx
8
Hi
, I downloaded 1030 from your link , extracted to sd card and
it didn't work ? Any ideas
