stel94
50
36
Dublin
I wrapped my badges a few days back. I now think the car looks as aggressive as it should do from the front. It's a pain in the ass to do unless you're very good with wrap Being the 3rd time I've used the stuff it's still tricky to get right. It's a good 5ft mod though, more of a proof of concept to make sure I like the black so I might paint them down the line. Happy to say the car is now chromeless on the exterior. :yes:#DeathToChrome
Good Job looks well, My cars Twin
stel94
50
36
Dublin
Lovely wheels on her, ill keep an eye out for ya around Dublin. What mm drop are those springs? How are they comfort wise? The roads around here are bad enough as is. Not sure I could put up with a harder ride.
:coolthumb 35mm , not much different slightly stiffer but very similar to stock spring but reduce body roll and feel alot more planted. Good thing with h&r springs is they are progressive spring made in two parts one soft then hard depending on how your driving the spring will work of softer section then stiffer spring when pushing on. Clear speed bumps with trc splitter which I was nervous to find out.
