Can anyone point me in the right direction for turning the diff setting using Carista also the false engine sound?
Sack that guys, managed to find them. Wasn’t looking hard enough haha
Just got my dongle yesterday, looks like the face lift Leon is no longer on beta testing
No, it just no longer listed as a car that is eligible for beta testing
I emailed them the other day, they sent me the link the following morning for the beta appCheers, have emailed the, will see what happens
Cheers all, on the beta now
Fancy have my rear lights on with the DRLs. I know it can be done on OBD11 but can't find it on carista. Am I just missing it or is it not there even on the beta?
Have you decided what you want to fiddle with yet?
It might be model spec/model specific if you can change it or not? I think the option is there anyway for things you can't change on your vehicle, in that it simply will not take if you try to alter a function beyond the module's capabilities.
https://caristaapp.comDoes the Carista work with any other obd2 apps for Android?
I cannot get any app to connect to it when its connected.
Hi.Thanks I have all of those options selected as well as the option ticked in the infotainment, I have just applied for the beta so will give that a go one it goes through. It certainly have the 2 sensor holes up by the map lights but cant determine if there is anything behind them. I assume not and its just a case of 1 facia / trim panel for all models. I cant believe that the alarm is an extra on a car of this price range, or that it wasn't ticked as the car was to be a demo model. But I did have to spec the alarm as an extra on my vRS.
Hi. If you have the senors then you have the alarm. Try this, get in the car, lock it, sit still for 1 minute then move around, should activate the alarm. A friend of mine does not have the sensors, I payed extra to have it fitted.Thanks I have all of those options selected as well as the option ticked in the infotainment, I have just applied for the beta so will give that a go one it goes through. It certainly have the 2 sensor holes up by the map lights but cant determine if there is anything behind them. I assume not and its just a case of 1 facia / trim panel for all models. I cant believe that the alarm is an extra on a car of this price range, or that it wasn't ticked as the car was to be a demo model. But I did have to spec the alarm as an extra on my vRS.
Hi.
