You have to log into your google account through the internet to access the beta version then you are "billed" via a test card daily for the duration of the beta use, think it is a month
I’m using iOS on an iPhone and not google. Does that matter?
Yes that is what I got and it does say google. I suggest you send them an email explaining you are using IOS and I am sure they will explain what to do. I found them very helpfulThis is what i had from Carista.
Note that I've also enabled "test purchases" for you, so you should be able to make any in-app "purchase" without actually being charged. Just make sure you see a note that says "This is a test order" in the payment pop-up from Google Play. The beta is valid for 3 months, after which you will automatically be removed (and you can continue using the regular version of Carista after that). If you are currently on a free trial, cancel it now; otherwise, the trial will convert to a real payment when it expires, regardless of whether you're in the beta.
All beta customizations are marked with a yellow "Send feedback" button. Please use that button to let us know which ones work and which don't. Also, if you run into any issues, with the app whatsoever, please reply here and let us know.
Thanks very much and happy testing!
Sent from my SM-A520F using Tapatalk
Nah parking isn't there. I was hoping to enable park pilot for my rear sensors. That being said, I really even want it lol it was just because someone said you can buy they had obdeleven.
Fuel quantity is just a another screen when you scroll through the driver's menu (mgp, speed, fuel consumers etc) it just tells you in Litres how much to refuel for s full tank
If you email them and ask for the Beta version the optical parking display setting is there, I enabled it on my MK3 facelift and it works perfectly!
Yeah I’ve signed up for the beta version but it isn’t working on iOS at the minute. I’ve tried for the last 6 days with no joy. Carista say it is a problem with iTunes not recognizing it’s a fake purchase or something. What are you using it on?
Oh that’s strange, I am using it on iOS on an iPhone 7 and it seems to be fine. Perhaps I was just lucky that it worked? Unless you uninstall and redownload the test version?
When did you try? I might try again today then. I have altered everything I can on the paid for bit. I get this error on the beta version
I made some changes yesterday including the parking distance display which is working. App is working okay today too, might be worth emailing Carista to see what’s going on.
Much do they charge you ? I only took it for a week so depends how much beta pro is before undecided if it's worth it lol
I know! The visual display is much more helpful than just the sound, I don’t get why it’s not enabled by default! I also enabled needle sweep and the refuel quantity however it only ever shows ‘- - - L’ which is odd
