If I buy a brand new sat nav sd card will it work?
kingy89
11
Stoke-on-Trent
Hi
I’ve just bought a 65 plate Leon FR with the Tech pack but there is no sd card for the sat nav. I’ve tried researching but I’ve not really got an answer, can I buy a brand new sat nav card and fit it without having to have it coded/paired to the car?
I don’t know what version should be fitted in the car but if it was for example v4, can I buy a v4 of eBay used and would it work??
Thanks in advance
p.eco
227
17
Ireland
99% not without adjusting the data. this however by reading another thread is not very simple thing to do. You better off buy a card from dealer....
zeffania
476
159
I am guessing you bought it privately? Weird that it wasn't in there as it will be useless in any other car as they are paired with the car
Walone
1,628
454
Near Heathrow
Hi
Thanks in advance
I take it that the Sat Nav doesn't work? If it does show maps then you will have Satnav High which doesn't have a separate SD card for maps.
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
I would go back to the dealer you got it from. Unless they told you the sat nav didn't work - and the vehicle was priced accordingly- then either they sort it at no cost to you or you give em the car back as it is not as described. With regards to getting a new card, unless your are an super techy type who enjoys talking gobbledegook whilst sitting in your underpants then the only alternative is the dealers, who will smile nicely, bend you over and drill you a new one.
AndrewJB
Aug 16, 2007
11,209
485
Maranello
No it needs to be the correct card for the nav unit. MIB1 cards wont work in MIB2 units etc.
it all gets a bit confusing.
AndrewJB
Aug 16, 2007
11,209
485
Maranello
New card will work because I have done it several times. a new card is blank, when inserted into the unit it pairs it then.
kingy89
11
Stoke-on-Trent
Just to update the thread, I purchased a used V3 sd card from eBay as it seemed this was most likely to have been fitted from new and guess what....
It worked
Thanks for your help guys
