I am so unlucky with this 1.8t
So..low mileage swapped AGU engine in 2005 Leon with 2005 ECU and VVT.
So, later i will post logs and graph...
Facts:
Stage 2 map
Forge fmic
Forge TIP
new k03s
76mm exgaust and downpipe
Got 175 hp and after 5500 massice drop in power.
Actual boost is the same as requested, no boost leaks
Fueling is perfect, from 14.7 to 11.5 on redline, enough fuel
MAF reading peak at 185,190 g/s
But power is very low, around 175 hp, so less than standard Leon...
Nobody has any idea wtf is going on..
What if i have worn out camshafts?
I tried a dyno run with vvt connected, and then dissconnected...graph is the same...
Only error i get on vag com is about secondary air injection incorrect flow because i removed it.
So there is a misterious loss of 40 bhp
Facts:
Stage 2 map
Forge fmic
Forge TIP
new k03s
