Fuel cap jammed shut
strummer
21
Emergency guys.
Tried to refuel today and fuel cap wont budge. Think the actuator may be a goner. Does anyone know if there is an emergency release and where? Took the boot lining and plastic trim away from behind the cap but can only see wiring looms. No cable release of any sorts. Manual as usual useless.
Running on 0 miles!
Thanks!
Miguel 7
R ST
Jan 23, 2017
349
56
29
I'd call Seat Assistance or something.. Make them come to the petrol station and fix it there
noonoo63
375
8
Scotland
See my thread re same issue. Whole petrol flap replaced under warranty no problem ( sorry actually AdamC11 started the thread)
ZK_FR150
220
32
Had the same problem other week, called seat assist out, they​ broke the latch with some trim removal tool.
Had the whole thing replaced under warranty.
Give the seat assist report in when u take the car to the dealers so they can't wrangle out of it.
Graham'sLeon3
11
Inside the boot,on the filler cap side There is an emergency release for fuel cap hidden behind the side carpet panel. Once you have the flap open I'd suggest you spray wd40 onto the black Push button release next to filler cap. It will need a bit of manual plunging & spraying until well lubed. This is due to sticking over a period of time.
JACUPRA280
932
56
Somewhere
This ^^^^
chrisRibiza
1,194
51
99% sure there is no emergency release on the mk3 Leon's.
There was a thread on here where someone stripped the inside of the boot looking for one and it didn't exist. Also the solenoid in the Leon is completely electronic, no manual wires are attached to it.
ZK_FR150
220
32
I'm pretty sure there isn't one too, the seat assist guy was trying to find it in the boot but couldn't.
As Chris said solenoid is electronic, once it's bust the locking plastic pin that usually spins and locks into the inside of the flap doesn't move anymore, so it stays latched onto the flap.
Only way is to replace the whole thing
