hello everyone!
i have 2008 seat ibiza fr and i did scan on vagcom and i had a few faults.
the only thing tht i didnt understand is the section about the climate.
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 06A 906 032 QN
Component: 1.8I R4/5VT 0020
Coding: 11500
Shop #: WSC 04941
VSSZZZ6LZ8R078673 SEZ5Z0G8291162
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AS
Component: ESP 8.0 front H05 0003
Coding: 0002332
Shop #: WSC 04941
No fault code found.
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
Coding: 0000000
Shop #: WSC 00000
5 Faults Found:
01273 - Fresh Air Blower (V2)
000 - - - Intermittent
00576 - Terminal 15
001 - Upper Limit Exceeded - Intermittent
00538 - Reference Voltage
002 - Lower Limit Exceeded - Intermittent
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 F
Component: 000B BN-SG. 2S36
Coding: 24716
Shop #: WSC 04941
1 Fault Found:
01598 - Drive Battery Voltage
07-00 - Signal to Low
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 823 G
Component: KOMBIINSTRUMENT AGD V04
Coding: 00101
Shop #: WSC 00000
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 04941
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 04941
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: Komfortger?t 0002
Coding: 00259
Shop #: WSC 00063
1 Fault Found:
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
End -------------------------------------------------------
i tried to make research on google but didnt understood what is the problem spesific to my car.
any help will Appreciated
p.s. the recirculation button dosent work when a/c is on so the air come from outside alwyas
thanks to all
Coding: 11500
Shop #: WSC 04941
2 Faults Found:
Coding: 0002332
Shop #: WSC 04941
Coding: 0000000
Shop #: WSC 00000
5 Faults Found:
00576 - Terminal 15
Coding: 24716
Shop #: WSC 04941
1 Fault Found:
Coding: 00101
Shop #: WSC 00000
1 Fault Found:
Coding: 00014
Shop #: WSC 04941
Coding: 10121
Shop #: WSC 04941
Coding: 00259
Shop #: WSC 00063
1 Fault Found:
thanks to all
