Had her put on the rollers on Saturday, didn't turn out too well.
First result was 222bhp/270ftlb, we then did a second run and returned 200bhp and even less torque.
Must have been something wrong, right? Well, pictures below....
The top boost pipe going onto the EGR delete had split, from where the clamp was done up fairly tight? So its either have it too loose so it won't split and it slides off, tighten it up and then split! I managed to pick up some boost pipes from Boost Junkies in Devon, comparing to the Darkside ones, much better, I can't believe how poor the Darkside ones are!
Anyway, that wasn't the main
problem, as seen, the lower boost pipe was sat on the roller! Create a lovely hole losing me all boost. I'm now running 0 PSI, this gets welded up tonight at Boost Junkies (Top Love to them for doing it on an evening after work!)
So hopefully tonight I will be running full boost, I'm arranging another dyno session for this weekend (hopefully).
I also took a Drive in the Cupra to Cheddar Gorge with this Beast.
