I cannot get this working....I get an error on the dash saying vehicle lighting fault....and the dtc on vcds shows light switch.
Have I missed something?
Great guide, thanks. Can you just confirm if the new sensor is visible through the screen or does is still hide behind the blacked out area. On our Octy, there is a clear glass circle where the sensor peeps out, but on the Leon, the circle is jet black?
my mirror is not the same as yours!
how is it different, can you provide photo?
i already had a light sensornot at the minute! I will try and get a pic
basically I dont have the capping between the head lining and the mirror mounting!
did you already have a sensor fitted and you swapped it for the light/rain sensor?
i got that error before i coded the sensor/ made the Adaptations, so make sure everything is set. I don't think i missed anything, but i'll recheck tomorrow
can't say i noticed, it looked black as always, i'll check tomorrow when it light
looks like you have missed something and not codded the left light
they are separate and need to be coded
go back and double check the coding
Could it be my light switch?
I have swapped back to the original and nothing has changed....anyone got any ideas?? please help lol
thanks
chris
I'll do it when I get home but I followed the walkthru above and my car didn't like it
Yeah so when you said:
STG 09, 31347, Adaption,
Leuchte 23 SL Lichtfunktion H „Interior Light“
Leuchte 24 SL Lichtfunktion H „Interior Light“
Dimming-Wert GH: 100 (case LED 126)
Dimming-Direction GH: Maximize
I only configured the "dimming-wert" for the 24 not the 23 - doh! All working good now though!
just gone over the settings and i missed one, when you tick byte 7 bit 7, you also need bit 5.
It confused me as bit 5 is Light Switch with Assistance Driving Light (ADL) installed, which as i understand it is to do with high beam assist which needs the front camera, but if i uncheck it i get the same error as you, so i t seems it needs it
i've added the reference pictures to the guide now
Phew, thanks and that's the same as our 180 TSI Tech Pack, so I guess that means we don't need a clear glass circle for the auto lights and wipers, not sure why its different on the Octy which got me worried after I'd already ordered the part. I've got a sensor on order from Germany, £41 incl delivery so hopefully can get the auto wipers working as soon as it arrives.this is how it looks on mine
