Greetings and happy Christmas everyone,
I know there are loads of messages on this topic, but none (that I've found) seem to answers my question.
I have a 2004 or 2005 Mk1 1.9 tdi 90hp. 5 door, sport limited - black (like that makes a difference).
I should explain also that I live in Spain, ironically recently having moved very close to where the car was built, so the car is LHD.
Ever since I bought it from a friend about five years ago, I've had intermittent faults with the central locking. Finally, just about a year ago, I had one the rear door locks replaced by a local garage at great expense, it had been playing up for quite a while before failing completely. With the MOT equivalent coming up, it needed to be sorted.
Now, a year later, I have the MOT looming again and this time it's the front doors that are misbehaving. The driver's door has been iffy for some time, it works when it wants using the remote, is fine using the key and sometimes responds to the button on the armrest. The passenger door, however, does nothing. It used to make a noise and not unlock, but now it does nothing whatsoever, it won't open. For a while, it would open after following a weird procedure: Open the car with remote, get in, lock the doors with the armrest button, start the car, switch off, remove key from ignition. After three repeats the door often opened.
To be fair, the guy who replaced the back door lock last year warned me the driver's door was on the way out, but as it can be opened with a key, I wasn't in a rush to give him another fortune to do that one too.
I've started stripping the doors down, not easy when you can't open one of them, but I'm getting there, the door cards are both off and the bolts removed from the passenger side sub frame. I've stopped now as I've run out of daylight and energy, it is also beer o'clock.
My first question is:
How do I know if this is a problem with the individual motors or the "brain" hidden behind the fuse board? I'm going to have to order parts, probably from Ebay, so I want to get this right first time, a question of time as well as money.
Other questions:
If I order from the UK where I've seen the lock mechanisms sold in pairs, does it matter that I'm getting RHD for an LHD car? I imagine they are handed, but does it matter that the key operated one is on the left on my car?
Another idea is to get a UK driver's door handle with lock and key and fit that, just in case - any thoughts?
Any help or advice will be very gratefully received.
Cheers.
PS: I've tried pulling fuses, disconnecting the battery, etc. No luck.
PPS If anyone can point me in the direction of a guide to getting the subframe out, that would be great too.
Other questions:
Cheers.
