Mega update I guess!!
It'll be very brief as I haven't got many pics.
Engine was in, then I set about wiring:
Then did the interior loom (no pics) but did set it up so I can have mains only (just as a 'I'm coming' setting on track after having a few near misses with people underestimating my approach speed.
DASH2 wired up and functional.
Total weight.
Then it was onto running in and mapping. Unfortunately this didn't go to plan.
After running in and an oil change I started doing the low end mapping. This all went well. Decided to try a couple of gate pressure runs. First pull with a footballer map (rich and retarded) did 249 at 0.6bar peak. Tweaked the fuel table and started another in which I noticed a rattle on the way up so immediately killed the ignition and got out to investigate.
With the Fuchs Titan race pro being red, the dyno cell looked like a murder scene. Nice spray mark right up the wall. And about 3L on the floor. ****. Set about investigation as to what had failed. Then noticed the oil filter had pulled off on 1 side. (This would explain the lack of oil pressure lights!) as it was still pumping but not enough pressure to sustain clearance from 3krpm. But why had this happened? Well, turns out the local Audi specialists parts lady had given me the wrong part. It was too small to notice the thread was different (M18 against 3/4unf.) - about 1mm difference, which would explain why I didn't notice it. So in urgency I popped over to the local factors and found the cheapest m18 oil filter I could. Just so I could start it and see if the motor had survived. It had thank god. But I called it a day to pull the sump off and inspect, rather safe than sorry! Upon inspection all the shells were scrap. However the crank was unharmed.
Then managed to get a set of mains and big ends of King racing bearings from TSR. Fitted them and have done about 50 road miles with it. All seemed well so booked the dyno again. Took it up to the dyno and started doing the mapping again. Did a base run that came out at 246, then added 3 degrees of timing, 269, then another 3 and got 304. Cleared the screen and went to get another run. This time 298. But noticed a rattle. Argh!!! This time it was box related. Pulled the end cap off the box to be greeted by a snapped circlip. Well atleast it was an easy fix. Hopefully!! Circlip a due tomorrow AM.
Here's a pic of the power graph. Happy with that at 0.6bar!
