Do you turn the screw with the lights on or off? (same for ignition, on or off?)
Can I try this on my car if I have auto level (or whatever is called)? Will the auto level not undo my manual adjustment?
Hello to all
Tried to do the above ...but to my surprise I can locate only one screw (number 1) as shown at the diagram where a member was kind enough to post ...
My leon is 2018 model ....does anyone has any ideas or maybe a fellow member with the facelift Leon ...has any ideas ?
Thank you in advance
Thank you Rolf ….…I’ve also got a 2018 model and just the one screw. I pointed the car at a wall and used that one screw which raised the height. I’ve adjust passenger 1/4 turn and driver side 1/2 a turn. Made a world of difference.
