Steering Sensor G250 Part Number Seat Ibiza 6J 1.4 16V BXW 2008
dm222
1,488
49
Hello,
Does anyone know the steering sensor part number in this car?
Thank you!
dm222
1,488
49
Also is it possible to replace only the cable between the pump and the sensor? Or is the cable attached to the sensor?
dm222
1,488
49
Looks like in all of them the cable can be replaced separatly
I think there is versions that cannot be replaced as the sensor is attached to it.
Thank you
dm222
1,488
49
Is this the power steering sensor cable?
Looks like it can be replaced only the cable...
MJ
5,594
45
Manchester
older cars had the cable wired into the sensor but on later cars it's all completely separate.
dm222
1,488
49
Does anyone know if in order to replace the cable it's necessary to remove the front bumper since it's dificult to acess the steering pump?
A mechanic said that he changed this cable in a Skoda and it was necessary to remove the front bumber in order to acess the pump to connect the cable but he doesn't know if in this car it is necessary to do it.
