Small update... since fitting oil pressure and oil temp sensors to work with FIS control I have had a little concern over the oil pressure on idle... occasionally I have had the three beeps of death but checking oil level, temp and pressure there is nothing to suggest a
problem other than maybe a faulty oil pressure sensor so... I have bought a new one but not actually fitted it yet lol...
In order to satisfy myself I bought a new OE oil pump from TPS (£150 sodding quid!!) to replace the Topran one I have been using... main concern was whether it had suffered from the over rev incident so in for a penny etc lol... I also bought some Millers Nanodrive oil to try... that was £55 delivered for 5ltrs!!... over £200 for an oil change!! lol
Whipped off the sump and the old oil pump....
Took the opportunity to inspect the bottom end and check the torque of the mains and big ends... all was good and no bits floating around the sump... phew!
Hot washed the sump, windage tray and 'old' pump
New pump fitted...
Sump sealant on ready to refit...
Filled up with the Millers... pulled the injectors to turn the engine over without firing to get oil into the pump and round to the vital bits...
Fired up, ran for a bit and topped off the oil level... engine seems quieter tbh but thats probably just the fresh oil... oil pressure wise its certainly looking ok... on idle before I have seen it fluctuate between 0.6 and 0.7bar at 90 degrees... now its a solid 0.8bar... this of course could still be down to fresh oil but that was after a little spirited driving so the oil should be 'fluid' enough by now...
In other news... the HPA controller had a moment and I ended up with a 500+ hp FWD lardy bus that wasn't much fun to drive (I feel for you Bill lol)... its moments like this you really do appreciate quattro (even if it is haldex lol)
There was a red LED on the controller so I unplugged the loom reconnecting the OE wiring to see if it was the haldex controller or the HPA unit and thankfully the haldex controller was working fine... that means the HPA was not liking something so have been in conversation with them and they suggested I have someone watch the LED status while I drive and report back... not the most practical solution so as I had recently treats myself to an SJCam (WiFi one) I decided to video it instead...
Reconnected the HPA and would it fault??? would it f00k!!... here is a little snippet of the video...
https://youtu.be/SVm7SIVy2Jw
Would was very apparent is the difference the HPA controller makes in terms of how the car feels... you really do get a sensation of being pushed along right from the get go... HPA have said there is an update to the firmware on its way so hopefully it will address the issue I have been having..
Of course as is tradition just when you think you are on top of things the car decides to keep you on your toes.... the ABS light came on the other day so switched to the ABS controller in FIS Control and read out the codes...
http://wiki.ross-tech.com/wiki/index.php/00290
00290 - ABS Wheel Speed Sensor Rear Left (G46)
Brilliant!!... will have to check the wiring etc when I get a chance... in fairness I had planned to replace the sensors when I do the rear wheel bearings but looks like those plans have been brought forward!!
Joys of car ownership
<tuffty/>
