ok sounds good.
Is it best to flush out the system first with water till it runs clear at the bottom and then do up the tap, fill it up again and put the lid on the header tank. Then idle or drive with the heater on full and then drain again and fill with coolant.
I take it this should get rid of any air etc?
yep, id flush the system till it runs clear then do the rad tap up.
Fill it doing a 50/50 mix (water/coolant) or whatever you choose...
I personally fill the coolant with a 50/50 mix till the coolant bottle is on its max marker then start the car and run it on idle with the heaters on hot so the fresh mix passes through the heater matrix, at this time i still have the coolant cap off so i can top it up if it does drop, an i squeeze the rad pipes top and bottom to release/move any trapped air.
Wait till i feel its HOT which means the stat has now opened.....
again top it up if need be and finally coolant cap back on.
On idle and with the heaters on hot will take a while for the engine to generate heat and get up to temp!
Take it for a little drive an have some fresh mix with you as its more than likely gonna need a top up
Sorted...Never had any issues doing it this way
