Got a few things for the clio.
First I got me weld in seat rails
Only doing the drivers side as I'll probably run 1 seat.
Next is to sort the rear axle out. The rear axle on these flex a lot aparrantly, so plan is to find a 182 rear axle as they run 24mm torsion bars (not sure what my cup runs atm lol)
So to get rid of the bushes I've gone for the puremotorsport bearing conversion kit.
Should look like this when fitted
Also got a stiffening kit
will have to cut a lot of brackets and spring plates off, aswell as reroute the brake pipes and hand brake cables.
Finished product should be like this
Last of all this is a picture of a Clio Cup Racer hubs
These are worth ££££ like 1K plus and you have to run the cup racer Bilsteins and top mounts which are more ££££ even second hand the prices are mental, but you the handling characteristics are ment to be awesome, so it's worth it.
I've a agreed with a guy to machine my hubs to the same spec as the cup racers, zinc coat them and supply me the roll centre and bump steer kit
can't wait for this costing me £650 tho but I'll have the same setup as the cup racers and be able to use my coilovers and top mounts
I'll also be upgrading my wishbones to bearings, removing the pas and adding light weight pulleys.
