Need help with Vagcom Faults
apsogos
RedGun
Sep 23, 2014
31
Good morning my friends...i am a newbie to vagcom.Need some help here...
VCDS Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 Data version: 20130910
No fault code found. Readiness: 0000 0000
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Tuesday,01,October,2013,08:35:01:40973
VIN: VSSZZZ6L******* License Plate: Mileage: 74850km-46509mi Repair Order:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009)) Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56VIN: VSSZZZ6L********* Mileage: 74850km/46509miles-------------------------------------------------------------------------------Address 01: Engine Labels: None Part No: 06A 906 032 QN Component: 1.8I R4/5VT G 0020 Coding: 11500 Shop #: WSC 78392 VCID: 7AFB146A667F54CEDA7-517A VSSZZZ6L********* SEZ7Z0E3061136
-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 6R0-907-37x-ASR80.lbl Part No SW: 6Q0 907 379 AG HW: 6Q0 907 379 AG Component: MABS 8.0 front H03 0002 Revision: 00000000 Serial number: 00000000000000 Coding: 0002241 Shop #: WSC 06403 785 00200 VCID: 820BEC8ADEAF9C0E027-517A
-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: None Part No: 6L0 820 043 B Component: CLIMAtronic PQ24 0301 Shop #: WSC 00000 000 00000 VCID: 25411716EF410B36C75-517A
3 Faults Found: 00778 - Steering Angle Sensor (G85) 49-00 - No Communications 01044 - Control Module Incorrectly Coded 35-00 - -01598 - Drive Battery Voltage 07-10 - Signal too Low - Intermittent
1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent
VCDS Self-Diagnosis Log Tuesday,01,October,2013,08:35:02:40973 Page 2
VIN: VSSZZZ6L********* License Plate:
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl Part No: 6Q1 937 049 D Component: 0000 BN-SG. 1S34 Coding: 16524 Shop #: WSC 06402 VCID: 3C77D2722CCBAAFE88B-517A
-------------------------------------------------------------------------------Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 6Q0 909 605 AE Component: 0E AIRBAG VW5 07 0010 Coding: 12357 Shop #: WSC 06401 VCID: 7AFB146A667F54CEDA7-517A
-------------------------------------------------------------------------------Address 17: Instruments Labels: 6L0-920-xx0-17.lbl Part No: 6L0 920 820 N Component: KOMBI+WEGFAHRSP VDO V13 Coding: 00142 Shop #: WSC 00000 VCID: 3561C7560FE17BB6775-517A VSSZZZ6L********** SEZ7Z0E3061136
1 Fault Found: 00779 - Outside Air Temp Sensor (G17) 30-10 - Open or Short to Plus - Intermittent
2 Faults Found: 00778 - Steering Angle Sensor (G85) 49-00 - No Communications 01044 - Control Module Incorrectly Coded 35-00 - -
VCDS Self-Diagnosis Log Tuesday,01,October,2013,08:35:02:40973 Page 3
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: 0068 GATEWAY CAN 1S34 Coding: 00014 Shop #: WSC 06402 VCID: F0EFB642B0039E9EE43-517A
-------------------------------------------------------------------------------Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6Q0 423 156 AB Component: LenkhilfeTRW V270 Coding: 10121 Shop #: WSC 06402 VCID: 6FED353E2D3D01667D9-517A
-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 6Q0-959-433.lbl Part No: 6Q0 959 433 E Component: Komfortgerát 0002 Coding: 00016 Shop #: WSC 06402 VCID: 3D71DF7637D1A3F6BF5-4B36
1 Fault Found: 00928 - Locking Module for Central Locking; Front Driver Side (F220) 27-10 - Implausible Signal - Intermittent
End ---------------------------------------------------------------------
Any help with be appreciated!
John
RUM4MO
7,933
1,046
South Scotland
Right, now that you have recorded all this stuff, clear all stored faults and take it from there. Sounds like the battery is or has been a bit low at some time, also the outside air temperature sensor could be faulty. Really as I said clear the stored fault codes and run it and then check it again, if the battery is low all the time sort that out first before moving on.
apsogos
RedGun
Sep 23, 2014
31
Hello and thank you for your fast answer.The truth is that the car is in a garage and goes for ride once a week, sometimes once in two weeks.Although i am very very cautious with my car.The battery is 1-2 month old and has never been below 12.35 volt.
the generator with car at idle with no other load is about 13.5 volts.
As far as the outside air temperature sensor (is this that measures the enviroment temperature?) if it is what i think , is it easy for me to replace it ?
RUM4MO
7,933
1,046
South Scotland
Yes it will be the outside air temperature, does your car have a display for outside temperature, if so is it showing the wrong temperature? Typically this probe is to be found behind the front bumper, maybe look through and down and in from the front grill, or remove the LHS foglight and look for a cable with a lump at its end clamped to the body. It should unclip and there is a plug and socket to disconnect it.
apsogos
RedGun
Sep 23, 2014
31
finally...there is no problem with outside temperature sensor...the steering wheel had wrong coding and my mech. change it.Everything is clear now.The only intermittent fault that has came up again is the central locking,front driver side 00928 - implausible signal
Sent from my SM-N9005 using Tapatalk
