ac123
So I bought My 53 plate LCR about a month ago now. It had 96k Long MOT and Tax and FSH. Just what I was looking for apart from a tad high on the mileage- but they are few and far between in Cornwall!
Everything seemed to be looking good, had a good test drive and it pled nicely through all the gears, no knocks or bumps. Two new tyres and the callipers and alloys had been refurbished about 12 months ago- the guy had still managed to curb them a couple of times unfortunately but otherwise it was pretty smart.
The downsides were
1. I believe someone had used a mechanical polisher on the paintwork which had been a bit aggressive, leaving some swirling.
2. The interior was a bit rough- a few stains and a bit of mould (which possibly should have been a warning sign.) However, I knew with some elbow grease I could sort that out.
3. It needs a cam belt in around 20k but thats a good way away.
4. It'll need new fronts shortly- which isn't so bad because I want to put some better tyres on anyway.
So I pay my money and off I drive. Happy as Larry...
Two hours later- the EML comes on. Great. Thankfully it didn't seem to effect the car, so I used it for a further day having checked the oil ect. Then it went into limp mode.
So the next day me and my buddy plug it into his OBD and it has a couple of fault codes, one about the thermostat and another being a misfire on cylinder four.
My friend diagnosed this as the coil pack on four needing replacement. Unfortunately I needed the car so had to take it to the stealers instead of buying the coil packs online and getting my friend to help. So £80 later Im back on the road- it also gave me a chance to get a rear wiper blade for a tenner too.
So then, two hours later- guess what? The EML pops back up so I plug it in and its the thermostat fault code again- for some reason we had figured they were related originally. So here starts the trouble which I have now read so many pages about.
We decided to replace the thermostat- believing it was stuck open as the temperature gauge wasn't moving on the dash. We did this successfully, taking 2 hours over a job you smart cookies do in twenty minutes. Of course, breaking the dipstick tube whilst we were at it and wasting five litres of coolant! It's all a learning curve though, ey?
However, we did eventually finish and put the car back together, plugged it back into the OBD and she was running at about 80 degrees- which my friend said sounds about right. It also got the gauge moving, but it goes down to sixty as soon as the car is moving- so I wasn't so sure.
Anyway I gave it a few drives- Plymouth>Bristol>Plymouth and the next weekend Plymouth>Southampton>Bristol. Everything seemed fine but on the way to southampton... Guess what pops up- the EML! By this point I have been smart enough to have bought a cheap OBD2 Bluetooth plugin and checked and cleared the code on my phone, same thermostat issue of course.
Another one I forgot to mention is the drivers side door lock is broken, causing the alarm to go off whilst driving ect. A bit of a nuisance, I have read about fixing it and it looks way above my very basic understanding, so I got a few quotes and have booked the car in for this. Whilst its there its getting the bodged dipstick tube replaced and I have now decided to get the guys to finally figure out whats causing the temperature problem- believing it to be the temp sender. Obviously for this I won't be going to the stealers and I have found a garage with good reviews in Plymouth and they are VAG specialists.
So keep your fingers crossed, this time tomorrow all of my mechanical and electrical issues will be solved! Hurrah!
Then I have a few plans- once it stops breaking!
1. Replace door seals (Have a minor leak in the passenger side door) I know it could be the pollen filter too but the door seals are tatty anyway.
2. Forge 007p
3. New air filter (not sure which one)
4. Possible re-map but I have not decided. (Currently running the standard 225bhp)
5. NGK Iridium Spark Plugs
And maybe this will change as I read you guys' advice!
Some of the things I have managed cheaply however is to get the interior looking a lot better, one or two more go's with the interior and cloth stain remover I have been using and the seats will be top notch again (Wonder wheels I think) and I have also got the body work looking better. Although she's dirty at the moment, but I need to give it a full clean, polish and wax which I have not yet done then I think it'll come up pretty good!
Sorry for such a lengthy post but I hope its been interesting. Please note I am a complete rookie and really have no idea about engines ect. This is a massive learning curve for me, my previous car was a boring Ford Focus, yet hugely reliable requiring two new tyres and a new windscreen (insurance job) and thats its after 10,000 miles of service. Prior to that I had a Ford Puma which Im not afraid to say was a great car for an eighteen year old. Cheap to insure and pretty nippy with the 1.7!
I hope its been interesting and i'll post some photos when I get some gooduns'
Thanks!
The downsides were
2. Forge 007p
Thanks!
