How to help your gearbox!!! Post 2003
ti
24
What did this resolve for you ?
Has anybody else performed this with any benefit?
Tigertim001
38
looks like i need to do this also. Anyone have the part numbers for the two parts or a link to where i can buy them from?
tully78
56
WHT-001-976 for the shim..
O2M-301-211-B for the black end cap.
That's everything u need.
The snap ring is a bit of a pain to remove.
dgjdrummer
Part-timer
Nov 5, 2011
1,310
Wrexham, N. Wales
Have just got this fitted, took about 30 mins out in the drizzle including jacking the car and taking the wheel off.
As I pulled the retaining clip off the whole shaft clearly moved a mm or 2 and once the shim was in there was no movement at all! The video on YouTube couldn't be any clearer, this really is worth doing as a fix or a prevention.
After a 10 minute test drive, gear changes feel more precise and there's no more droning in 5th gear when I lift off the accelerator! Thanks massively to Tully for the heads up :thumbup:
chrispcupre
767
9
leicestershire
That's good news hopefully it will quiet down mine abit aswell
tully78
56
It's a pleasure mate. Glad it worked for you.
Certainly made a difference mines been good as gold since.
Did u lose a bit of oil when removing black cap?
dgjdrummer
Part-timer
Nov 5, 2011
1,310
Wrexham, N. Wales
Yes mate, only about an egg cup worth though.
Chris - it will sort the noise out straight away, mines been quiet and have done another 20-odd miles since fitting it earlier.
Dec 5, 2012
806
Harlow
just like to add I fitted the parts suggested by tully and its totally cured my whine/drone in 3rd. it started to sound soo bad but after fitting this its quiet like a new gearbox! and I agree with dgjdrummer the gearchanges feel more crisp.
massive thanks to tully as I was planning on sending the box off to be rebuilt and now I don't need to :)
