Fitted a new battery and used some g3 scratch remover and sorted out some annoying scratches.
Got my car back from garage yesterday.. Now with my 3" Cobra exhaust fitted.. liking the new sound ;).
Next issue the passenger window regulator has failed and my window is now stuck at the bottom of the door. :cry:
just fitted the egr delete. just a quick question. you know the 2 vacuum pipes on the egr. i've put a screw in the one that was connected at the top because thats what i read somewhere. but what do i do with the other one that comes off the egr actuator and goes to the switch bolted to the inlet manifold? i've done the same and put a screw in it but not sure if thats what i'm supposed to do.
added a pillow on top of my drivers seat in the leon as the bolsters have metal bars sticking out :(
Its a diesel :) I thought the ultimate range was good. Tbh I used to use vpower in my old mk3 golf gti & it was much better than the bp.
Fitted something blue to the car half an hour ago.
SFS AH13/A 80mm TIP, surprised at the difference it makes even with just a smoothed airbox and Pipercross panel filter!
Just need to fit the bigger clamp to the MAF as I left it at work :/
Removed the diesel filter bracket and gave it a good clean then sprayed black, followed by a couple of clear coats - looks far better whe bonnet is open :)
i've been having limp mode issues for about 2 weeks, so yesterday i replaced the vacuum hose's with silicon ones and this morning i gave the turbo the mr muscle treatment. its pulling great now :)
