on an LC you must use a 70-80mm silicone reducer.
Surely that's a 80mm-70mm reducer
Is there a heat shield for this set-up available on the market or will it have to be a custom jobby? Just got the filter for £11, fitting it today. Can't wait!
I fitted an s2000 filter the other day... Rang up to book my map in with AMD and they told me to take it of as will loose to much power from heatsoak, is this true as im liking the sound of it with an open cone on. Will it be enough of a power loss to worry about??
No for the lc 180 you need a reducer from 80mm-70mm
