carparts4less is the sister company of ecp
Scrap that, it was £12.90. Shows the green one in the picture but its red and black that was delivered
http://www.carparts4less.co.uk/cp4l...fb89e4b2c2e4172fd67c045955c0d178fcfaad&000008
It comes lightly oiled, I wiped as much of the oil off as I could off of the plastic parts inside and out.
Would it not be better to use a silicone joiner reducer to join the cone to maf? I love that the japs made cone filters oem those pesky noodle eating geniuses!!![]()
I think you'd be hard pushed to fit a silicone joiner in there man. If you look at mine it's real tight to the wing. The filter itself has got a slight raised bevel on the inside so when pushed hard enough it clicks nice and snug over the MAF anyway.
It's mad the only difference is no local shop to pick up from it's all posted but it's so much cheaper
Do your self a favour and cut down the middle of the plastic about 2 inches,
That will give it some flex which allows it to go on further and clamp down better with a jubilee clip.
Also I used a bit of silicon to make sure its formed an air tight seal.
