Battery relocation *GUIDE HERE*
Sep 22, 2011
713
Hemel Hempstead
Hope this helps other people save some money but if you go to screw fix or somewhere similar you can get 1 of these for 3.50 does the exact same its called a Henley block
HOLLANDMSGH
50
Planned to do an accu boot swap this winter. so this is good for me.
Whats with the small fuse to the relais?
Can you explain?
Equalizer
103
Poland
Could you tell me where I can put the power cables from the engine bay to the cabin? There are no pictures anymore in the first post. I would like to use a 21mm2 wires, and the hole near brake servo is to small.
