Can you remove your injectors and send them to these company's, I assume they remove them to clean them anyway?
smash the granny out of the car. That'll do just as good of a job of cleaning away deposits, is cheaper, and much more fun
As mentioned, my LCR is an '03 and I've had it for 5 years. For the first 2.5 years I used V-Power only; ever since, it's been mostly Sainsbury's SUL (97RON) or Momentum99, with occasional V-Power (no Shell garages locally).Thing is the people already use v-power/nitro+ /whatever it's called this week and THEN use terraclean and get good results.
I bet 6th.replicant only uses the best fuel.
Tunap method doesn't remove the injectors - also worth noting that Tunap also simultaneously cleans the inlet valves and combustion chambers, etc, whereas, obviously, the remove injectors/send-away method does not.Can you remove your injectors and send them to these company's, I assume they remove them to clean them anyway?
