6th.replicant
698
9
London
My LCR has no engine-related running problems to speak of, but when giving it full beans - eg, from 2,500 to 5,700rpm in 3rd or 4th - its 1.8T felt slightly 'lumpy' as it revved and there was a definite sense of 'steps'/stages as the power kicked-in and increased - and low-rev throttle response was less than sparkling.
But hey, that's all typical of a turbocharged engine, right? Or maybe not...
My LCR is just over 10 years old (ie, Jan '03), has done c. 80k, is OEM spec, apart from a Forge 007, and I've owned it for the past 5-ish years. During which time its fuel diet has been an inconsistent mix of V-Power, Momentum99 and Sainsbury's SUL (97RON).
I'd heard that having the fuel injectors cleaned by a specialist can be beneficial for cars 'of a certain age', so I decided to take a punt.
I looked at Asnu's method but it's a bit of a faff - the injectors need to be removed, sent away for c. 48 hours for cleaning, then re-installed.
Then I noticed a local indie garage does injector cleaning on-site, without removing the injectors, and while-you-wait (it takes c. 1 hour), using a German set-up called Tunap, which, allegedly, is what Merc recommends/uses.
In effect, Tunap works like a kidney dialysis machine: it pumps cleaning fluid through the injectors and, in turn, it also cleans the inlet valves and combustion chamber.
Had my LCR 'Tunaped' this afternoon. Impressions? The engine 'feels like new', literally.
While leaving the garage, I immediately noticed that low-rev throttle response and torque is significantly improved and it generally feels 'lighter' and more eager to rev - the last mentioned is especially noticeable when blipping the throttle during down-shifts.
And in comparison, when revving in-gear from 2,500 to 5,700rpm, it now feels smooth and linear - more like a sweet-revving normally aspirated motor - and it definitely has more mid-range and top-end punch overall. (The roads were wet from rain this afternoon, and the TC light has been uncharacteristically flashing like a lighthouse.) :funk:
Not a bad result for £89 incl VAT [B)]
Also, diagnostics as follows:
  • 0.001% CO
  • 6ppm for HCs
  • 0.999 for Lambda
  • 15.38% C02
Although, whether the above figures are a consequence of Tunap, I'm not sure.
Here's a vid showing/explaining Tunap, albeit with a dollop of marketing hyperbole and a clunky German-to-English translation - clickety
Looks like he also uses it as hair product :blink:
a mate of mine got this terraclean stuff done to his e30 325i sport at the weekend and it is unreal the difference! used to smell rich as f**k now u can put ur nose ryt at the exhaust and smell nothing its that clean. and the amought of extra grunt is astonishing considering his car was a good going thing to start with! cost him £120 due to the size of the engine and im definitely getting this donw to my cupra r!!
name of the garage who did this please? :D Need to find one local to me in west sussex who does this... thanks for the heads up!
I'm booked in at Monster-Sport in Milton Keynes to get mine Terracleaned at the end of the month. They have agreed to run an emission test before and after too, so ill post results when i get them :)
Might look at this for my LCR, only 16 miles from me so I might give them a bell.
I'm gonna give mine an oil change and new plugs first and book it for after that.
tbf I'd just get a full tank of V power or Nitro or whatever the new one is called and smash the granny out of the car. That'll do just as good of a job of cleaning away deposits, is cheaper, and much more fun
Sorry but if you saw the car on wheeler dealers and there is more proof around
http://www.jaguarforum.co.uk/f19/terraclean-seen-wheeler-dealers-my-results-45958.html
Only thing is, we don't know if that Jag has ever been past 4k RPM... That might be the reason it's so clogged up, and as such the terraclean seems like it's doing an amazeballs job.
Ideally two cars with similar level of clogged-ness would be used, and one terracleaned and one a full tank of vpower and a good hammering, and compare the results. However I doubt any terraclean "dealer" would ever be willing to do that, as if it proved that terraclean was just useless, there'd be no need for it and no money to be made :lol:
