been a while since i've updated this so better do it:
well the car is now back on all 4 wheels! 99.9% of the boost pipes is now finished. all routed nicely but too many joins so once its all up and running gonna get some custom pipes made with less joins. just got to get some hose for the dump valve recirculation back into the intake and some jubilee clips of the intake side of the turbo. all turbo oil/coolant pipes/connections are now all tight. made up a tempory oil breather for now just venting behind the bumper until i can afford a catch tank. its all filled up with fluids....oil, coolant, p/s fluid etc. left the front top and bottom strut braces and o/s driveshaft off for now as it will be easier to access the downpipe for when it gets made. think i will take it to Infinity Exhausts for the downpipe to be made! started wiring up the external fuel pump. routed the wiring inside to find a live and will run it off a separate switch which will be hidden. brakes have been bled. manual boost controller is fitted under the bonnet but will move to the dash once its been mapped.
so with all this done it was time to crank it over and circulate the oil. i connected the battery and gave the car power and then realised i didnt have the key with me!!! so will grab the key and do it tomorrow!
still to do: need the downpipe made, heat shield around the brake fluid reservoir and bonnet, dump valve recirc hose, and mapping!
