Have you had xenons before? That sudden cut off surprised me at first. If you are used to std lights they are a lot less focused. The intensity would blind other drivers if it didn't have the cut off.
Scott
Snarks, did you order the Driver Assist Pack? That's what had the high beam assist and lane assist, don't think it's part of the tech pack.
Theres definitely something ive read in the Leon literature that states that the lights do something to stop dazzling other drivers.....?
Andy
Finally, I came across a Spanish video review of the new Leon in which the daylight running LEDS seem to be doing some odd things at about 3.56 and 4.59 in the video (again no URL, but the site is called coches.net and the review was posted on 29 January). Do these lights double as indicators? Even if that is the case, it doesn't explain the second phenomenon - unless the LEDs are acting as hazard warning lights. Any ideas?
Were the LEDS flickering by any chance? it's do you with the frequency of the cameras compared to the LEDS, if you watch top gear you see it happen to the rear leds on the cars as they film. so it's not a fault with the car.
fyi you can't see them flicker by human eye incase you are wondering.
Yes that might explain the phenomenon. In the video (posted on 1 February), the daylight running LEDs (I think) appear to be "winking" alternately between the left and right headlights. I suppose that switching them on and off at a very high frequency would save energy and reduce heating of the LEDs.
Snarks, so do the LED headlights have AFS? And if they don't is it not needed with full LED?
I saw some videos from the Audi A7 Full LED startup sequence and it seemed that they only move up/down, no lateral movement.
It's got automatic range adjustment but I've seen no evidence of the beam moving from side to side as I turn the vehicle.
The same Spanish video review mentioned above (1st Feb on coches.net - I still can't post links yet) shows an animated display on the infotainment screen in which the (head?)light beams appear to move as the steering wheel is turned (at about 2.35 in the video). This may be showing how the foglight beams move when cornering.
According to one online report, Ford has developed adaptive lighting functions which adjust beam pattern to vehicle speed and cornering attitude to provide the best possible illumination of the road ahead without dazzling oncoming vehicle. I'm not sure whether this is the same as AFS but it looks like it's up to the vehicle manufacturer to provide these functions and it doesn't look like SEAT are offering similar functions - for now.
