Team GTR - Leon Cupra R
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Where the FECK have all these pages come from when I'm subscribed?!?!?!
Car look amazing on the new rims bro and nice on the detailing gear......good hangover cure too (to clean the car not drink the products)
What you got in the bucket? List the products dude.
You been neglecting me :( lol
Cheers mate. In the package we have the following:
Br!dges
753
Wales
Don't blame me bro, blame the websites notifications lol!! :)
Good products to get you started...... but just wait for it to increase and increase and increase and your wallet gets lighter and lighter lol!!! :p
TBM is the only way to go and keep rinsing that mitt after every body panel :)
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
I forgot you was getting the QD :D
Ahhh crap I forgot to purchase the actual QD solution..........fail. Il stick it into Tom's order ;)
Sent you a PM mate with a few pics of the seats to post on facebook.
Posted mate!
Just out of interest, what size are your number plates mate?
Front plate is: 330mm x 112mm - 13 x 4.25
Got it from createmyplates.com
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Thanks for that, I'm looking at ordering the same wheels in Steel Grey, I'm assuming that they don't clear the brakes without spacers, is 10mm sufficient?
I was looking at the steel grey for mine but then opted for the gunmetal colour in the end (can't remember why though :confused:)
They don't clear the calipers unfortunately so spacers will be required. These come in et44 or et48 so the size of spacer needed will depend on which offset you go for. I was originally going for et44 but after I ordered them Rota decided to tell me they only have 3 wheels left so I had to go for et48 in the end
John Lindsay
146
Hamilton, Scotland
Again, Rota only have them in ET48 so thats what I'm going for. Decided on Steel Grey because my car is black, and I think the gunmetal would just be a bit too dark, they look well on yours though!
You reckon they would clear the brakes with 10mm up front? That should make them the same ET as a standard LCR wheel.
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Do you not get loads of poke?
No poke at all mate. They sit about the same as when I had OEM wheels with 12mm spacers up front and 15m spacers at the rear. I calculated it all so that they sat within the arches
Steel grey should look great against the black mate. 10mm may fit but it will be really close. Let me check my car and measure the space between the wheel and caliper for you
8bit
3,401
Aberdeen
Are the 15mm bolt-on FK spacers pretty decent? My R32 wheels don't clear the Brembos so need spacers. I want to use the same width front and rear so whatever I get has to fit onto the rear hubs, I know some spacers don't (as D.K found out) so thinking about ordering the 15mm FKs.
How quickly did they arrive when you ordered direct from Germany?
EDIT - and did they come with bolts?
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Before I had the H&R spacers on the rears and had zero fitment issues. The FK spacers also fitted properly, but with these you also bolt them to the hub so it has no room to move
They came very quickly mate, think about a week and they give you tracking numbers so you can be a impatient geek like me and watch it every step of the way :) These spacers come with the bolts to mount them to the hub but then you need bolts to secure the wheel to the spacers. The site says you can use your OEM bolts but I purchased a new set of bolts. The front ones needed trimming slightly though as they were touching the spacers. The website says you should be able to use your OEM spacers with no issues so thinking this happened to me as its aftermarket wheels :confused:
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
@John Lindsay
I have just taken a couple of pics to show the gap between the front wheels and the calliper. This is with 15mm spacers, so I would say 10mm is going to be tight
Excuse the dirt, car needs a proper clean. Weather spoilt it all this weekend :(
