k1fro - just saw our update in your RR, they look spot on mate! :thumbup: How does it sit with the bags raised? Have you driven with them yet?
Darren - glad to hear it's coming together, get some pics up already! No major progress on mine, just some small bits like getting everything ready for the de-lock so I can fit it once the rain stops and got my brake carriers ready to go on so I can do my big brake conversion.
Drives really well n I can drive with the rear all the way down n for just above the tyre
*update*
Right well the stickerbomb has gone, the car is lower wqith 20mm still left to lower more :D Here is a picture for itsa feature in Performance SEAT published on the 20th :D roll on UD!!
Credit to Andy Pilcher for the picture
This dubsfest any good? just bought tickets never been before. anyone reccomend hotels nearby? Going down on the Saturday I think
Lookin much better guys, should be a decent club stand!
Matt, where can I find my SKC and could you take a look at a couple of bits with mine too please mate?
Unless you want immobiliser or clock work doing then I won't need the SKC. You need either a dealer or VagTacho to get the SKC
What do you want doing?
Auto Windows (1CO CCMs only)
One Touch Unlock
Auto Lock
Auto Unlock
Alarm Chirps
Indicator Flashes
German Alarm horn
Error Code Scan
Idle Speed adaption
Throttle body alignment (not applicable to TDI engines.)
Cruise Control activation (requires CC stalk and loom to be fitted)
key in ignition - door open" warning gong
and so on :)
No nothing immo or anything, lookin at:
Auto windows - mine will come down on key/fob but not go up again, would like to work out how the F to do it properly!
Alarm chirps (maybe, see how annoying it is)
Door open gong
maybe some other stuff but not sure yet! Would be hugely appreciated :)
How did you get the windows to go down on the fob? I could only make it happen using coding.
The alarm chirp isn't that annoying, I have it set to chirp only when I lock it.
I'll bring my laptop so if you need anything let me know :)
I don't know, it was like that when I got it. I have a slip of paper amongst all the paperwork I got with the car detailing the fob syntax, will have a look for it and post details here...
Ok, instructions for Auto Windows BASIC & BRITE models.
OPEN - [UNLOCK] [UNLOCK] [UNLOCK] (unlocks doors, opens all windows (not sunroof)
CLOSE - [UNLOCK] [LOCK] (locks all doors, closes all windows and sunroof, alarm on)
ONE-TOUCH UP - [LOCK] (performs CLOSE if enabled, requires POWER PACK to be enabled)
STOP - [UNLOCK] (immediately stops windows/sunroof)
RETRACT - [UNLOCK] [UNLOCK] (Stops windows/sunroof, retracts windows (all down))
There are also mode selection settings but I guess that's what can be done via VCDS? I can bring the sheet with me to UD if you want it for reference? There is also an AUTO BRITE function for cars with the BRITE package but I don't know if that applies to our cars. It basically turns the headlights on when using any of the other functions.
