Now I dare say this has been discussed before, but I have actually gone a head ànd done it, so this is a little guide to how, what, why & results:
Put simply this is the perfect mod for people that have had the infamous sticking rear calipers on the Ibiza FR, Fabia Etc, with the calipers sticking the usual result is that the handbrake doesn't release fully, so you will experience a variety of different symptoms. Mine was blocking tyres, hot rear brakes, increased wear on brakes ànd a slack handbrake.
Thr calipers fitted to the Ibiza ànd fabia dont come with the helper springs as standard, they have to be ordered from VW, just ask for the release springs for the 2002 VW Sharan they work out at £3 each.
When fitting you,'ll need to make sure that you fit them the correct way round otherwise it will have the opposite effect. The correct way is like so:
As you see the 2 prongs of the springs are matchingthe shape of the caliper. If you look closely at the picture you can make out the 2 holes where these slide into.
Now this is fitted when the spring is released (once the handbrake is taken off) thr spring is then applying pressure on the 2 parts of the caliper, moving them further apart, ànd moving the caliper away from the disc.
Since doing this I have found that all of the symptoms I described above have near enough cleared up, when taking the handbrake off it snaps down which is nice as it means I know the springs are doing their jobs. I have also noticed the brakes have a touch more bite to them now the calipers have re adjusted
All in all for the sake of 30mins rolling on the floor, ànd £6 you need to try this first before replacing the caliper as it might just save you a fortune!
Tapatalk on Xperia S
