Not the best of luck lately with the car. We all go through these moments when things decide to bite us in the ass and you get seriously annoyed with the car as a whole and think about selling it or even burning it.
Before I got the bushes done I started getting a lot of noises around the suspension area. Got the car on the ramps and noticed my CV boot decided to take a run for it meaning the CV joint ran dry and started knocking. This was fixed the same time all the bushes were getting done.
Whilst driving the other day I went over a speed bump and heard a loud clunking sound which then my steering went out of alignment with plenty of vibration through the steer wheel. The tracking is fine as the car goes in a straight line when you let go of the steering wheel but in order to go straight the steering wheel needs to be turned to the left. It may be down to the CV joint running dry and more damage being caused but not sure at this point. The traction control light also came on and when I scanned the car I got the following error code come up:
Address 03: ABS Brakes Labels: Redir Fail!
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 06402
VCID: 40F355F4538D
1 Fault Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure - Intermittent
After whining away like a little b1tch I decided to man up and get the car sorted instead of getting annoyed with it and looking at alternative cars to splash out on. I have booked the car in a local garage who has done other work on the car to see what is going on with the above issue. Whilst there it will be getting a few other bits done also:
- Clutch inspection - want to know why the clutch vibrates so much when crawling in first gear. If you launch the car it's fine and all other gears are fine, only in first when crawling in traffic I get a lot of irritating vibration
- New radiator - current one is leaking
- Chain gasket is being replaced - it's where my oil leak is coming from
- New calliper springs - when reversing I get a whining noise which is due to these wearing out
That's the list for now, car is booked in for the 15th so will add to the list if needs be. The way I see it, these cars are awesome fun when they are running right so I might as well get these sorted and continue enjoying the car. Plus the car owes me plenty more track time
