So today was essentially dyno car with std inlet, fit large inlet, dyno car again...
Car on dyno... ran the car up on the std inlet... I am running on just actuator pressure at the moment until I have the S4 MAF and 90mm TIP in place as I don't want to be buggering around chasing my tail on the mapping until all the changes I know I am going to make are done...
First run had some boost creep for whatever reason and made 310hp @ 17/18psi peak... subsequent runs were 15psi consistently so maybe the Tial needed some heat in it to get it working right... second run netted just over 280hp... the EGT's were low 700's only spiking at 750 on lift off (no flow through the engine to cool)... that was at a steady 15psi..
Then fitted the manifold.... cover off...
Cover on...
Results were impressive...
17ish hp gain just by bolting on the fabricated inlet... was happy with that...
Clearly the map needs tweaking but then this is the first time the car has been on the dyno with any of my maps on so overall very happy with the result considering its been tweaked from road logging etc..
Fuelling is going into component protection (KFLBTS) as I have the EGT trigger set quite low... logging EGTs showed this can be upped a tad so will sort that later... it going rich cost me a bit of power top end too so if AFR had carried on rather than get rich then it could have made another 5-10hp based on what I normally see on the dyno
Overall really happy with the result, happy with the map and looking forward to getting the S4 MAF and 90mm TIP sorted hopefully next week..
<tuffty/>
