Which RNS 510?
magicman
I want to install the RNS 510 to my FL Cupra. Will all versions work or do I need a particular one? There is 'J' version now from what I can see.
Deleted member 74601
I believe they should all work, the letter just relates to the revision of firmware the unit is currently on. I'd just get the latest.
Sinbad
238
Johannesburg, South Africa
Not strictly true.
Revs A and B had older hardware (smaller hard drives, slower processors, LCD displays).
Rev C has 40GB and LED - so anything above C is what I'd go for. Beware - ANY A,B or C unit upgraded to newer firmware will show itself as a rev D. Use VagCom to check the real version number or look on the outer casing of the unit.
