LCR Head gasket, leak?
May 13, 2007
1,017
Denmark
Hi all,
After fixing the vacuum hoses underneath the manifold, for good using forge replacements :eek:)
I had a bad feeling yesterday on my way home from work, so this morning i used my pressurekit and remove the airfilter og popped on the kit(http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=160792014038&ssPageName=ADME:L:OC:US:3160)
Didnt unplu anything else and just applied pressure gently, already at 0.3 bar I hear the hissing...went for some soap solution and then found the leak... On the left side (reverse end of the belt) of the top gasket... Soooeh....Is this a DYI job?
And, is this "normal" ? Cars gone 155.000, running 1,45 bar ATM
Best regards,
