Hi Guys, sounds like your having fun, I am still trying to decide if this will be same probs as mine, as mine is a low rev stutter although accasionally get on when you plant the throttle hard, where did you get the EGR delete kit?. and is it still running fine?. cheers again
My stutter was also around the 2k (low rev range)
EGR delete solved the problem for me. alot of help from AndreJB!
He knows his stuff =]
Oh and is it still worth cleaning the EGR first? and do we think the small holed gasket is still worth a go? thanks.
I guess the EGR is worth cleaning, but it will only get dirty again, and end up doing the same thing over time, so unless you got alot of time i wouldnt bother! just get EGR delete^^
