What power could I expect from my TDI 150 Leon after the following mods?
cairns81
newbie here, just doing some reading up, keep up the good work, im learning away! thanks guys! :)
gdjohny
Crazy Mechanical Engineer
Dec 25, 2010
815
Kettering
Oh
Speaking of filters. I had a Pipercross in my TDI and after few months it killed the MAF.
There was a lot of info about the original filters on VAG range and in every case the conclusion was the same : If you not goint BIG TURBO etc there is no need to change the original filter.
My 5p
leonfrtdi150
Thanks for all your comments very interesting.
I've had my car mapped now with the following mods in the end:
*Universal intercooler with some hard piping
*EGR delete
*Straight through 2.25" exhaust (cat and backbox removed)
Car made 200.3bhp and 346ft lb - just wondering if people think these are reliable and realistic figures?
john_tdi
mmm 385lbft
Feb 21, 2007
687
s wales
I would take it with a pinch of salt. 346lbft is really high for a stock turbo pd150. That kind of level is produced from hybrids.
If the torque figure is high then Id say the bhp is also, as bhp is a calculation from torque.
The intercooler wouldn't of given any power over stock and the exhaust would have given a small increase.
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,291
Belfast N Ireland
Get an exhaust gas temperature probe put in and monitor the temperature before the hot side of your turbo. I don't know what the maximum allowable temps for yor turbo is but when you find out you can add fmic misting and water methanol injection into the intake manifold and reduce the temps. You should be able to get the tuner to ask the ecu to let the engine produce more power safely or at least if it is maxed then you will be able to safely monitor the turbo. You would not believe the difference that inclines make to temps.
bruceR
2,554
643
Monifieth, Dundee
Having read thru this thread I would tend to agree with the main upgrade being a remap.
I fitted a green panel filter 5 years ago and clean it regularly (as per instructions) and have had no problems.
I had a custom remap shortly afterwards and it read: before 157bhp, after 193bhp/292lbft.
I have just recently got a cat-back non resonated Milteck exhaust fitted but only 'cause my original exhaust t finally gave up the ghost after 7 years!!!!!!!!
Anyway, enjoy your mods
Oh and last month I fitted the allard egr delete pipe, to keep my engine clean but had the dreaded elm light come on - hay ho
georgemckee999
39
Bishop's Stortford
hello im new to the forum. i am looking at getting my standard fr150 remaped as its become apparent that that's the best mod to give it that extra boost. bruceR was it just an air filter from standard when you got the figure of 193/292lbft??
georgemckee999
39
Bishop's Stortford
All those extra horses and only needing it changed every three years, I would be happy with that. I have been told if I want to keep the standard clutch to keep it under 300lbft so I think that's what I'm gonna aim for. Thanks for your help :)
georgemckee999
39
Bishop's Stortford
Exactly :) I thought if I was to remap I would need an updated clutch to deal with the extra power, but as you have been fine without the upgraded clutch I'm more confident that I wont need one.
joshy514
Fleet Air Arm by ability.
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
You can't just say you won't need a clutch haha! I've seen people on here with stage 2 maps about 220 I think with a standard and he says slip comes and goes, on the other hand people with just stage one get slip too, it will come down to the condition of clutch etc
Feb 22, 2009
3,618
South Wales
Just pointing out I had this happen to me after my remap
allthough I supose it was actually the DMF failed
jamming solid at an angle.
