The engine fitted to both vehicles is of the same basic design and share the same capacity, bore, stoke and compression
measurements. The mechanical components such as block, crank, pistons, cylinder head, camshafts, inlet & clutch are the same.
The Borgwarner turbocharger is also of the same specification, though the intercooler is slightly modified on the CDLA, fitted
to the Cupra R. The engine control unit (ECU) is also different, with the software inside the unit mapped to deliver the
additional power.
The gearbox fitted to both vehicles is to all intents and purposes of the same 02QJ construction. The only slight difference is
internally, where the 4th gear ratio in the LMN fitted to the Cupra R been 34 : 31 = 1.096 as apposed to 41 : 37 = 1.106 in the
KZW unit fitted to the Cupra.
The Cupra & Cupra R normally run on the same G63 suspension (though G51 is available on some Cupra's) so the ride would be
comparable. The Cupra R does however run slightly different alignment settings as it sits 3mm lower than the Cupra.
