MJSeatcupra
OK so here is abit of a guide to fitting a boost gauge- i could not find a direct guide on here- so mumbled my way through and took pictures at various stages- hope it helps people- 1.8t engine
so first off i removed headlight switch/surround- as i used the switch wiring to power up the gauge-
the screws holding the panels on are pretty obvious to find-
unclipped fuseboard cover for access- plus id later run the wiring up through the loom
i then soldered the boost gauge power loom into headlamp rotary switch loom- i wired it so it would be white during day and red when sidelights activated- i have it written down if anyone rqs it.
my next issue was i could not for the life of me find a way to get through or find a rubber grommit to push wiring through into engine bay- but the n/s was fairly easy to get to- soooooo i exstended the loom provided- (soldered/heat shrink) and ran it down back of dash board- this was a hassle but only as daylight was nearly gone
removed end of n/s dasshboard to route loom and glovebox lid for access.
picture of loom routed through bulkhead- i used a braising rod to get through rubber grommits- once again a pain!
i then began routing vac pipe for boost gauge reciever- easy bit!
then secured vac line-
routing of loom up to top of dash
and the finished article!!
and a little video of start-up
http://youtu.be/Otz_IDBmBNo
as always- neither i nor the forum are responsible for you wrecking your car-
