Productive day.... while Bill was having a much deserved day off I cracked on with fitting the tray for the battery relocation...
Removed the back box and heat shield so I could access underneath for bolting stuff in...
Worked out where the tray was going to go... up against the back of the boot...
Marked it all up and made spacers as the boot floor isn't flat... bolted it all down, looking good so far...
As I am using a lead/acid battery inside the car (albeit in the boot) you need to vent it externally... batterys usually come with two breather holes, one each side and a little plug to plug one up if needed...
I then modded a 90 deg pipe joiner (6mm one IIRC... its one I had kicking about..) and there is a handy grommet next to the battery for running the vent pipe outside...
Drilled the hole for the earth lead and cleaned off the paint to get a good connection...
Used an M8 SS bolt and made a stud for the earth lead to connect too... made an earth lead from 50mm sq welding cable... crimped the terminals on for a solid connection...
That all done I sealed all the bolts and holes underneath with high temp sealant... seam sealer would have worked just as well but didn't have any to hand...
Thats the tray in... need to pull out some of the interior now so I can run the cable to the engine bay (I already have my 4 gauge amp cable run so will need to replace that and re-route to the back)... also need to trim around the boot carpet and make a trim panel to fit over the top of the battery as it will stick up a bit... I have another S3 boot carpet to use to trim the panel... job done...
With that done I got on with a full brake fluid replacement as when I tested it the other week it was over the limit moisture wise... I used ATE Blue fluid this time rather than Motul RBF660 this time mainly because Bill had it on the shelf...
Cut myself a little funnel out of a water bottle and bled away... all four corners, clutch and master cylinder...
Good thing about the ATE Blue is I could easily tell when the old fluid had bled through as the tube went blue...
Once that was done I did a quick check over the coolant hose clips and as expected they felt loose again... this is fairly typical of silicon hoses... boost pipes are the same... usually have to go around the clips again after a day on the dyno after the initial build...
Happy days
<tuffty/>
