Hi guys, I need some expert help, some mechanical help and if possible some local garage/mechanical help.
You may or may not be aware that I have been having some mis-fire issues. I was having the “lumpy” engine not running properly symptoms. So I change the Coil Packs, still mis-firing, changed the spark plugs, still mis-firing. So I decided that I needed a garages help.
Towed it to my local VAG specialist, they have run several tests and have told me the verdict, and its not looking good.
No compression in cylinder 3. They are going to have to strip the engine, head off to see what the damage is. Could be a burnt valve, could be a bent rod, literally who knows until they have had it stripped.
I asked him to talk me through it – cylinder head off, check everything they can and see why they are losing compression, check the pistons, rods, valves, take the head gasket off get that stripped down tested and pressed/skim the head. Then once they have seen what the problem is, fix it. Then put it all back together again with the new valves, timing belt, gaskets etc.. Honestly I’m looking at circa £1000 and I can’t afford/justify it at the moment.
So – what I need advice/help on is who lives local to me (Hampshire) that could help with this? Anything else worth changing whilst the engine is stripped bare?
Should I give up on it and strip/sell the car?
How much can be DIY/over a few days coz if it’s cheaper I will SORN it, buy a £100 1.0l runaround, insure that (saving more money) and then strip it on the drive with as much help from as many people as possible, buy the parts and rebuild the engine. I am of course willing to look at anything right now so I need some help, fast!
If you have any ideas please list below, or PM me and I would be more than happy to give you my mobile number so we can talk more.
I have a fair few mods on the car and its running stage 2 revo – last dyno was 280bhp and 313lb torque.
