Leaky Leon
Proff_86
115
West Midlands
Guys, could someone tell me what the best sealant is to use when sorting the common pollen filter leak ? Is it just a case of re-beading the existing sealant? I did use the search function but couldnt find a definitive answer...
This bad weather has left my Leon like a swimming pool inside! :(
Tr1ck
236
Cornwall
have you checked the seals around the window regulators.. they are very common, i had to do both of my front ones
6th.replicant
698
9
London
Butyl-strip seems to be the weapon of choice for doors, so I assume it also works on pollen filters?
images
Welcome to Lake Leon.
5,275
Wolverhampton
I don't remember there being ANY sealant on the pollen filter. It's a replaceable item, you'd be replacing the sealant every time?
It leaks if it's not fitted properly, but I don't believe it needs to be sealed?
6th.replicant
698
9
London
True, but doesn't the housing also leak? Maybe not?
Proff_86
115
West Midlands
It's definatley the pollen filter, discovered it a few weeks ago and thought I'd cured it, but it's leaking again. Auto glass had done a replacement screen a couple of months back and It seemed like the cover had been put back in badly. I took it all apart and put it back in and seemed fine. If u lift the filter out there looks like there's a beading of sealant around the locating edge of the ducting? Thought this might be the problem does this sound about right?
