Stage 1 Cupra Revo Fuel Pressure Request
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
Hi
Could any one tell me what a Stage 1 Cupra Revo map should be requesting for fuel pressure?
Mine is requesting 130 bar....... It can only achieve around 120 bar on standard pump so why is it requesting 130bar?
I have a flat spot around 5700rpm in 4th+ once I have changed from 3rd to 4th and trying to get to the bottom of it.
Not sure what the issue is.
Plugs have been changed and new Fuel Filter. Car is a 2010 Cupra with 5k miles on the clock
3rd to 4th gear log:
Code:
	Group A:	'003				Group B:	'020				Group C:	'230
		Engine Speed	Mass Air Flow	Throttle Valve Angle	Ignition		Timing Retardation	Timing Retardation	Timing Retardation	Timing Retardation		Rail Pressure	Rail Pressure	Rail Pressure
	TIME	(G28)	Sensor (G70)		Timing Angle	TIME	Cylinder 1	Cylinder 2	Cylinder 3	Cylinder 4	TIME	(specified)	(actual)	Difference
Marker	STAMP	 /min	 g/s	 %	 °ATDC	STAMP	°KW	°KW	°KW	°KW	STAMP	 bar	 bar	 bar
	0.27	2960	111.22	99.6	13.5	0.02	0	0	-3	0	0.13	128.27	119.36	8.91
	0.64	3320	134.61	99.2	9	0.39	-3	0	-3	-3	0.52	129.76	118.87	10.89
	1.04	3640	142.83	99.6	4.5	0.78	-3	-3	-3	-3	0.91	129.9	118.32	11.58
	1.42	4000	150.78	99.6	9	1.16	-0.8	-2.3	-3.8	-2.3	1.3	129.9	118.58	11.32
	1.81	4240	167.89	99.6	12.8	1.55	-0.8	-2.3	-3.8	-2.3	1.68	129.96	119.83	10.13
	2.19	4560	181.36	99.6	12.8	1.93	-0.8	-2.3	-3.8	-2.3	2.06	129.99	118.16	11.82
	2.58	4880	189.33	99.6	14.3	2.33	0	0	0	0	2.46	129.99	117.6	12.39
	2.97	5200	202.31	99.6	13.5	2.7	0	0	0	0	2.84	129.99	118.84	11.15
	3.36	5480	215.56	99.6	13.5	3.09	0	0	0	0	3.22	129.99	118.23	11.76
	3.73	5720	224.64	99.6	14.3	3.49	0	0	0	0	3.61	129.99	118.78	11.21
	4.12	6040	235.56	99.6	14.3	3.87	0	0	0	0	4	129.99	117.71	12.28
	4.52	6280	241.83	99.6	15	4.25	0	0	0	0	4.38	129.99	119.92	10.07
	4.9	6520	243.44	99.6	15	4.64	0	0	0	0	4.77	129.99	120.34	9.65
	5.28	6760	247.72	99.6	15.8	5.02	0	0	0	0	5.15	129.99	118.69	11.3
	5.67	7040	248.61	49.4	8.3	5.42	0	0	0	0	5.55	129.99	120.9	9.09
	6.06	5920	158.22	53.3	24	5.79	0	0	0	0	5.94	130	127.32	2.67
	6.45	5280	231.81	94.9	9.8	6.18	0	0	0	0	6.3	130	120.59	9.4
	6.82	5400	194.17	46.7	11.3	6.57	0	0	0	-2.3	6.69	130	119.57	10.42
	7.21	5520	183.11	98	18.8	6.96	0	0	0	-2.3	7.08	130	120.23	9.77
	7.6	5680	243.67	98.4	9.8	7.33	0	0	0	-2.3	7.47	130	119.49	10.5
	7.99	5800	247.28	98.8	7.5	7.73	0	-1.5	-0.8	-1.5	7.85	130	116.95	13.05
	8.37	5920	214.36	99.6	12.8	8.11	0	-1.5	-0.8	-1.5	8.24	130	120.39	9.6
	8.76	6040	237.67	99.6	15.8	8.51	0	-1.5	-0.8	-1.5	8.63	130	119.09	10.91
	9.15	6160	247.81	99.6	10.5	8.88	0	-1.5	-0.8	-1.5	9.02	130	119.07	10.92
	9.53	6280	249.22	99.6	12.8	9.27	0	-1.5	-0.8	-1.5	9.39	130	117.88	12.12
	9.92	6360	243.19	99.6	13.5	9.66	0	-1.5	-0.8	-1.5	9.78	130	111.46	18.54
	10.3	6480	199.17	69.4	7.5	10.05	0	-1.5	-0.8	-1.5	10.17	130	120.03	9.97
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
Are you sure you have the stage 1 code?
according to REVO on their sales log it says that the current revision of the Stage 1 file was installed at 9:47am.
Thats why I want to know if the stage 1 file should request 130bar or not to make sure that I am running the correct file for definite.
Is there any other way to check.
Jan 1, 2006
764
Sheffield
I don't have REVO, but my GIAC flash loader tells me which map is loaded currently. Would the REVO SPS have the same function?
S3Power
Hi
Code:
Hello people!
Please can you help me?
I remap my car 2.0 TFSI (Revo Stage 1) and I get exactly the same ...
The fuel pump of claim 110b passes (stock) to 130b (Stage 1).
This is normal? For that gasoline demand so much pressure?
The stocks HFPP is not able to deliver throughout the rev range the 130b (from 3000-6300 rev) does not reach the defendants 130b.
Regards!
May 25, 2008
1,919
S.Wales
www.seatcupra.net
Hello people!
Regards!
looks fine? it's not going to max at 130... but the actual request = 127.32 based on these results...
If your getting flat spots...worth checking for boost leaks and mis-fire counts
Mite be worth calling REVO or posting this at the REVO section
S3Power
Hello.
I've posted in the section Revo.
I can not even post pictures on the forum (to have 15 post or more) when I can post pictures featured a graphic (vag com channel 230) so you can see what I get.
Greetings.
S3Power
The new revised Revo code doesnt request anywhere near 130 bar pressure , iirc its more around 120 bar max.
Hello and very thanks robdf2!
Only in the new versions of Stage 1 (REVO) require less than 130b?
Regards.
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
My flat spot issue was sorted when I got the new updated STG1 REVO code.
Not sure what it requests now as I haven't logged it but I do know that the flat spot has totally disappeared.
S3Power
Hello and thanks!
I can not post pictures because it is new (need 15 post) when I can hang the fuel pressure graph of my car when I was on set and now remap with Stage 1 (130b).
You got to ride a piston type Autotech kit?
Regards.
