mark garfoot
191
sleaford lincs
hi my car splutters and holds back when boosting mainly under 3000rpm can any one help me read these logs and give me a clue what could be causing this?
i have changed plugs (bosch super 4),coilpacks,boost hoses, upper and lower breather pipes,recirc valve,n75 valve,maf,temp sensor no codes are showing on vagcom its starting to really get me down now as i carnt seem to pin point the problem
Thursday 10 November 2011 14:18:06
06A 906 032 HN 1.8L R4/5VT 0001
Group A: '115 Group B: Not Running
Engine Speed Engine Load Charge Pressure Charge Pressure
TIME (specified Value) (actual Value) TIME
Marker STAMP /min % mbar mbar STAMP
0.01 2000 53.4 1000 1080
0.49 2080 88 2420 1180
1.01 2160 106 2400 1380
1.41 2240 118 2410 1530
1.81 2360 130.1 2330 1660
2.21 2440 139.1 2270 1780
2.61 2520 145.9 2300 1890
3.01 2640 154.1 2350 1990
3.41 2760 164.7 2410 2120
3.82 2920 173.7 2440 2220
4.22 3040 182 2440 2310
4.62 3160 185.7 2430 2370
5.02 3280 187.2 2430 2330
5.42 3440 185.7 2410 2270
5.82 3560 183.5 2420 2240
6.22 3680 182 2440 2260
6.64 3800 179.7 2470 2240
7.04 3920 175.2 2490 2200
7.44 4040 172.9 2500 2200
7.95 4200 169.9 2500 2190
8.35 4280 169.2 2500 2170
8.84 4440 167.7 2490 2120
9.24 4560 166.9 2480 2120
9.66 4680 165.4 2470 2100
10.06 4760 164.7 2470 2090
10.46 4880 162.4 2460 2050
10.86 4960 161.7 2460 2020
11.26 5040 160.9 2470 2030
11.66 5160 161.7 2470 1990
12.06 5280 159.4 2480 1990
12.48 5360 158.6 2490 1950
12.97 5440 157.9 2500 1970
13.88 5600 10.6 0.09 200 140 033
138.9 1960 51.1 1010 1060
139.29 2000 82.7 2420 1120
139.69 2080 97.7 2390 1280
140.09 2160 110.5 2390 1430
140.49 2240 122.6 2380 1570
141.01 2360 136.1 2370 1730
141.5 2480 147.4 2390 1880
141.9 2600 153.4 2420 1980
142.3 2720 162.4 2480 2100
142.7 2840 172.2 2510 2210
143.12 2960 181.2 2550 2310
143.61 3160 189.5 2500 2370
144.01 3320 189.5 2450 2330
144.41 3440 188.7 2430 2270
144.81 3560 184.2 2440 2230
145.23 3720 184.2 2460 2260
145.63 3800 181.2 2490 2250
146.03 3960 176.7 2510 2220
146.43 4080 174.4 2510 2210
146.83 4200 172.2 2510 2190
147.23 4280 170.7 2500 2170
147.64 4400 169.9 2490 2150
148.04 4520 168.4 2480 2130
148.54 4640 166.2 2480 2100
148.94 4720 166.9 2480 2070
149.36 4840 163.9 2460 2060
149.76 4920 163.2 2460 2060
150.16 5000 163.9 2450 2020
150.56 5120 162.4 2460 2000
150.97 5200 160.9 2470 1980
151.36 5280 160.2 2480 1980
151.77 5360 160.2 2410 1990
152.27 5440 159.4 2280 1960
152.67 5520 157.1 2230 1940
153.07 5600 157.1 2010 1930
153.48 5680 154.1 1850 1910
153.88 5720 146.6 1640 2060
154.28 5760 97.7 1450 1550
194.81 2000 18.8 1010 1030
195.32 2040 85.7 2250 1140
195.81 2120 106.8 2200 1360
196.21 2200 121.1 2210 1530
196.61 2320 134.6 2230 1700
197.01 2400 146.6 2240 1840
197.43 2520 154.9 2250 1950
197.83 2640 163.2 2280 2080
198.23 2760 171.4 2330 2200
198.72 2920 181.2 2390 2320
199.12 3040 189.5 2420 2420
199.54 3200 191.7 2400 2410
200.04 3360 191.7 2400 2360
200.44 3480 190.2 2390 2270
200.95 3640 184.2 2420 2280
201.44 3800 182.7 2450 2280
201.84 3960 180.5 2480 2240
202.24 4040 176.7 2490 2240
202.66 4160 173.7 2480 2220
203.16 4320 172.9 2480 2180
203.55 4400 170.7 2470 2140
203.95 4520 168.4 2470 2140
204.35 4640 167.7 2470 2100
204.77 4720 166.9 2460 2110
205.28 4840 166.2 2460 2080
205.68 4920 164.7 2450 2060
206.08 5000 164.7 2460 2040
206.47 5080 163.2 2470 2030
206.88 5160 161.7 2470 2010
207.28 5240 160.9 2480 1990
207.68 5320 160.9 2420 1970
208.18 5400 157.9 2320 1970
208.58 5520 157.1 2210 1960
208.99 5560 154.9 2060 1950
209.39 5640 154.9 1910 1940
209.81 5720 153.4 1780 1950
210.31 5760 147.4 1460 2070
210.71 5800 98.5 1520 1500
211.11 5840 138.3 1810 1740
211.6 5920 153.4 1640 1910
212.02 5920 98.5 1350 2040
296.39 1920 26.3 1000 1040
296.79 1920 26.3 1000 1040
297.19 1920 35.3 1000 1030
297.59 1960 34.6 1000 1040
298 1960 34.6 1000 1040
298.4 1960 34.6 1000 1050
who map your car mate , requesting alot of boost very early , 1.4bar at 2200 rpm , the boost logs don't look to bad from wher i'm sitting but bosch super 4 are shite , get oem ngk
For some reason it didn't splutter today when I did logs, but I could still feel it holding back, map tech uk mapped it for me, but before it was done I occasionally had a slight splutter on boost but alot worse fiancé it's been mapped
Lambda sensor??? My LCR was acting like a twat at low rpm until I replaced the lambda sensor.
Mine never! Had a dodgy lambda sensor & it engine light did not come on!
Code:
