Now reclip in the plastic trim.
I measured out and marked the location of my holes. I then drilled a 5mm hole.(No photos of this! Sorry)
For the next part, i never took step by step photos as the camera's battery died.
Basically, i put the mirror housing back on, and then positioned my mirror to suit my driving position. Held the led mounts in position, so that they illuminated the gear surround, and then dabbed them with hot melt glue. Once happy with the positon, i applied a fair amount of glue.
In some parts i drilled holes inside the mirror housing to feed the cables through.
This is how it looked once i had it all put together and connected the cables up.
This shows one of the back holes i drilled to feed the cable through.
Pluged in and illuminated.
This is how it looks from the underside. You cannot see them when driving, unless you dip your head down.
Now, down at the fuse box, i drilled holes again, to create a route for my cables.
This shows my live wire with inline fuse (3amp).
This is the slot i have plugged into. It is a switched live, so comes on with ignition. Note that depending on the spec of your car, this slot may be occupied by a fuse, so you will have to just try and find an empty one.
I earthed onto the chassis, using an 8mm bolt and a nut on the other end. The wire has a crimped ring connector on the other end.
Hopefully this is of use. I do not have photos of the results yet, as i my phone camera was not up to the job of night photos.
I would say my LED's are a tad bright. They look good shineing onto the gear stick and dark surround, but when you hand goes underneath, it appears too bright. Brighter than my dads Audi.
I suppose resistors or something could be used to dim the brightness. Will give them a go and see how they go for a week or two.
In all, im happy with the result. Although i may change them to come on with my sidelights, just as my dads Audi does.
