Hi all,
I am hoping that someone here could please share their knowledge of the FK Hi-Tec Suspension kit for the Ibiza mk2 and help answer some questions I have regards correct assembly of the rear shock components.
FK part numbers:
Kit: FK 99 SE 003
Shock: FKZZVW39 46 - 05
Lower Spring Plate: 232968
Sring: FK45/FKS45 HA
With the rear shocks its possible to adjust the height position of the lower spring supporting plates by repositioning a spring clip within incremental grooves along the shock:
On top of this then rests a larger collar which then in turn supports the lower spring plate:
In the first of the 2 images above you can see that the collar has a recess on the inside edge of one face. This happens to be exactly the right size for either the spring clip on the shock OR the inner diameter of the spring plate to fit inside.
My question would be which one is it intended for???
Also in the second picture above I believe I have the spring plate upside down and it should actually support the spring as in the image below - Is this correct?
How do I determine how much the spring needs to be rotated on the plate to ensure its correctly seated?
Really appreciate some help on this to establish the absolute correct way of installing the as I don't want to do it twice or more!
Many thanks!
DC
FK part numbers:
Kit: FK 99 SE 003
Many thanks!
DC
