When I was saying "Mikalor" clips I meant these ones that itfben found (note that's the brand name, not the type):
i think these would look smarter than cable ties, what size you reckon I / we should go for for 8mm hoses? 12mm 11mm?
I just didn't understand this bit mate
there is no rule to say what you can or cant use, i use what fits best and this is the out come
good quality hose is the key
order from this shop, this is the same place i buy my silicone hose from and the quality is very good.
http://cgi.ebay.co.uk/2-Metres-Blue...CarParts_SM&hash=item56448f9577#ht_1100wt_905
SAM!!!!!!!
the 8mm wont fit for the U shaped hose! took the old one off (now have not clip to hold it back one, stupid 1-time-use-clips) the 8mm hose actusally fits INSIDE the oem hose so its more like 14mm that 8mm
doh!
Alright dudes im taking mine off the road this week to sort out everything I wanna do well a large portion of it and I wanna smarten up my engine bay. How much 8mm hose would I need to order and how much 10mm hose?
Thanks Ben
Also does anyone know what size fuel pipe is on the LCR i wanna order some braided hose.
Thanking you plenty
Has anyone done or got similar info for the PD150 engine? which hoses can just be swapped with silicone vacuum hose and what sizes are required? Engine cover is staying on so it's only really the visible ones that I want to do.
Cheers in advance
Also is it possible to replace the PCV pipes with silicone,
I don't want to do the delete, Just renew the check valves and pipework.
infact buy this, you will have everything you need and more
good price aswell
http://cgi.ebay.co.uk/Red-Silicone-...CarParts_SM&hash=item3362210099#ht_1302wt_905
Thats my bay, should have just asked me.
1,2,4 are indeed 8mm and 3 can be 10mm but is a bugger to get off, the other smaller hoses are 3mm.
Ronun225 is correct.
Also don;t use cable ties, get the proper silicon hose friendly jubilee clips, they look alot better, more durable and can be reused.
You can get all these from siliconhoses.com cheaply
Here is an updated pic for your to copy!
