First, oil mist started blowing out of the Forge spacer onto the turbo pipe, then I found oil in the intake pipes so I vented the breather pipe to atmosphere, then it started smoking as I pulled out of a junction. TSR have stripped down the block - no.1 piston is gone, (the injectors are not flowing enough fuel) and the big end bearings are worn. Looks like it needs pistons, bearings, injectors and an adjustment to the map. Not exactly happy about that, have asked TSR to build engine stronger, guess I will have to miss GTi Inters, 1st time since I started going in '95. s*** happens.
