lisbong
Hi,
New to the forum and wondered if someone can help me?
I have an ebay vag com cable (OBDII - USB) and vag com 3.11. I used this on my previous car which was a mk4 golf and it all worked fine.
I've just bought a 2004 Toledo TDI and can't get it to work. I connect the cable and run the com port test which comes back fine. The correct com port is selected and looks ready to go.
I then try to run an autoscan. There is no Toledo option in the chassis list but I read on the forums that the Leon (1M) option should work. I select this chassis and run the scan.
Everything starts as expected but then nothing gets reported? It just goes through each module (eg 01 Engine etc) and eventually moves onto the next without generating any output (fault codes etc). It eventually gets to the finish and the just says END........... with no fault report.
Any ideas what's going on?
